Jeep Cherokee strip
macgyvr
NAXJA Member #120
NE Indiana
4.0 motor no accessories but includes head, intake,exhaust manifold, water pump - $400
motor is pulled
Hear it run:
https://youtu.be/on7yEXkGKyI
https://youtu.be/MvUaJqiDo68
Can load motor in your truck or trailer.
Alternator $40
Starter $25
Power steering pump w/reservoir - $30
CPS, IAC, TPS - $10 each
Motor mounts - $10
Tranny mount - $10
Driveshaft rear - $30
Aw-4 4sp auto transmission - $200 ea (actually have one from a 96 and from a 97)
Rear 8.25 w/track-lok - $200
Driver's fender - $60 w/inner and flare - $50 w/o
Hood - $85
Electric fan - $30
Mechanical fan shroud - $20
Rear tail lights - $25 each (only passenger's side left)
Year old fuel pump - $50
Gas tank - $30
Gas tank straps w/all hardware - $20
Interior door panels - w/ power switches $25 each (will bundle)
Window regulators - $20 (drivers front, rear passenger/driver left)
rear windows - $10 each
factory radio cassette - $40
transmission gear selector with handle - $20
interior switch panel w/rear defrost - $20
hvac control panel - $40
center trim bezel hvac/radio - $25
transfer case bezel np242 - $30
Center console - $40
Wiper regulator - $15
Wiper arms with blades - $10 both
Washer fluid reservoir w/motors - $40
Air box - $15
Sway bars rear - $20 - front $20 - links $10
Hvac blower with cage - $15
Master cylinder w/reservoir - $25
transmission/tcase cross member - $40
Good steering column with key, wheel with cruise, is worn, clock spring got cut. - $50
I also have a driver's side airbag that will fit a 1996-1998 Jeep Grand Cherokee - $50
mac 'starting a pile of parts to bring to winterfest' gyvr
UPDATED 12/30/2016
http://fortwayne.craigslist.org/pts/5885448007.html
I can bring anything to Winterfest. Larger items MUST be pre-paid by paypal before I will bring them along.
1997 Jeep Cherokee Sport part out
motor is pulled 229k ran good
Hear it run:
Alternator (reman) $40
Belt - $10
mechanical fan/w clutch - $25
Mechanical fan shroud - $15
Electric fan - $25
auto flex plate - $15
radiator overflow - $15
Motor mounts - $10
Tranny mount - $10
Front calipers/pads/rotors $40 side or $70 for both
Front hubs - $20 each
Hood - $85
Gas tank - $30
Air box - $15
Other items available except list below and tcase and front axle.
Text for more pics and offers.
Everything is Or best offer, but be reasonable.
260-four oh two-3387 text or call
Will bundle
UPDATED list, more than just 97 parts, garage clean up!
http://fortwayne.craigslist.org/pts/5945581210.html
Hear it run:
Belt - $10
mechanical fan/w clutch - $20 (have 2 of these)
Electric fan - $25
auto flex plate - $15 (have 2 of these)
I have the radiator. It's in good shape, but the mounting on the bottom is rusty and you'd need to use your mounting. Look at the pics. $30
Motor mounts - $10
Tranny mount - $10
Rear 8.25 w/track-lok - $150
Steering box spacer - $15
Steering box - $40
Hood - $85
Rear tail lights - $20 each (only passenger's side left)
Gas tank - $30
rear windows - $10 each (3 sets)
Master cylinder w/reservoir - $25 (have 2 other is a 96)
Other Jeep parts for sale include:
Driver's side airbag that will fit a 1996-1998 Jeep Grand Cherokee ZJ - $50
Stock spare tire cover for ZJ
1996-1998 ZJ driver's window master power window switch panel
1996 ZJ engine computer (4.0/auto) - $75
1996 Jeep Cherokee engine wiring harness w/PDC - $50
1996 Jeep Cherokee engine computer (4.0/auto) - $75
1996 Jeep Cherokee transmission computer (aw4) - $40
Other items available except list below and tcase and front axle assembly.
Will bundle
Motor is sold.
mac 'everything else listed is still up for grabs' gyvr
I don't know if you want to go through the hassle of packaging and shipping (to Alaska 99507), but I am intrested in a good mechanical fan shroud.
Text or call (907)440-0786
Fan shroud is on it's way to Alaska as soon as the post office starts moving again after the holiday.
mac 'tell me what you need' gyvr
Muffler, radiator, and driver's side rear window sold today.
Rear axle, a transmission, and interior panels are pending.
Also have a guy that says he wants the alternator and steering box...but we shall see.
mac 'will update complete list later' gyvr
I had added to the add a 96 XJ ECU and a 98 ZJ ECU.
Both are sold.
mac 'still more forsale' gyvr
Updated list: 1/22/17
91-01 2- mechanical fan/w clutch - $20 each
2- auto flex plate (91-01) - $15 ea
Various (91-01) CPS, IAC, TPS - $10 each
91-01 Motor mounts 4.0 - $10 set
91-01 Tranny mount (auto) - $10
Driveshaft rear (97-01 auto 242 tcase)- $30
2- Aw-4 4sp auto transmission - $150 ea (96 and 97)
84-01 Steering box spacer - $15
84-01 Steering box - $40
91-01 Front calipers/pads/rotors $40 side or $70 for both
97-01 Front hubs - $20 each or $30 pair
97-01 Hood (white) - $85
97-01 cowl (white) - $15
97-01 Year old fuel pump - $50
97-01 Gas tank - $30
97-01 Gas tank straps w/all hardware - $20
97-01 Interior door panels - w/ power switches $25 each (will bundle)
97-01 Window regulators - $15 ea(drivers front passenger, rear passenger/driver)
84-01 quarter rear windows - $10 each (3 sets)
84-01 rear door window pass side - $20
97-01 interior switch panel w/rear defrost - $20
97-01 transfer case bezel np242 - $30
97-01 Wiper regulator - $15
84-01 Wiper arms with blades - $10 both
84-01 Front sway bar (newer poly bushings) - $20
Front links $10
97-01 HVAC blower with cage - $15
2- brake booster Master cylinder w/reservoir - $25 (96 and 97)
91-01 transmission/tcase cross member (fits automatic)- $40
97-01 Good steering column with key, wheel with cruise, is worn, clock spring got cut. - $50
1996 engine wiring harness (w/PDC)- $50
1996 TCU transmission computer (aw4) - $40
Jeep Grand Cherokee (ZJ)
1996-98 drivers side air bag- $50
1993-98 Stock full size spare tire cover (dark gray)
1996-98 driver's window master power window switch panel- $30
mac 'money talks' gyvr
updated 2/5
Jeep Cherokee and Grand Cherokee parts.
D30 axle shafts
-All Dana 30 spicer stock shafts and all large ujoint stock unless noted (shafts in pics):
-long side shaft no ujoint - $30
-outer - $20
-short side complete SMALL UJOINT - $25
Cherokee (XJ) parts:
Various (91-01) IAC, TPS - $10 each
1996 Aw-4 4sp auto transmission - $150
84-86 Front hubs - $20 each or $30 pair
Front links $10
mac 'more of a parts thread instead of a strip' gyvr
Updated 2/18
https://fortwayne.craigslist.org/pts/6008499239.html
D30 axle shafts
-outer - $20
Front links $10
mac 'WF is coming! Money talks!' gyvr
I don't have a ps pump.
mac 'I do have some undocumented cruise pieces' gyvr
