Jeep Cherokee Freedom?
July 15th, 2008, 00:07
Ahem.
lol! I am trying to be reasonable with both party's of this "story". But in the end, I personally thought someone needed to help you out on clarifying the real truth behind the freedoms...I'm not one for defensive people that are mislead, and slightly confused. ha.
This thread is full of fail and reaching epic "Who the heck cares?" status.......
:D
Small update, another Freedom owner contacted me today, their Jeep was built 2 hours after mine and its VIN is 5 digits before mine. Thats the closest production freedom I have come across to mine.....might be the closest one period! Both are yellow as well. I've been trying to figure if the production of colors went in batches at the time. Another yellow Freedom owner contacted me and their Jeep was built 3 hours before mine, so the run of yellow might be true.......
Wow..... impressive thread revival! 2011 to 2019!
It would make sense that they would do paint runs rather than individual colors based on build orders. I imagine the process to change paint color in the assembly line function is a bit of a time delay and somewhat involved.
Yes, though from what I have seen of other recent lines the colors vary as they come out the pipeline, the next one is different from the last one, but I don't know how Jeep did it back then.
I also discovered something else now that I had these two vin numbers, the freedom production is sequentially numbered! The freedom production went by counts of 5.
After learning this I was able modify the last digit but increments of 5, and then calculate the checksum for the 9th digit, then with the completed vin number I was able to plug it into the build sheet lookup and confirm that my guesstimated vins were in fact freedom edition Jeeps.
All of these vins are from freedoms, and I only know them because I made guesses and checked with the build sheet.
1J4FF48S5YL211575
1J4FF48S6YL211570
1J4FF48S2YL211565
1J4FF48S3YL211560
Now here is the interesting thing, on the build sheet you see color, and they appear to be grouped, and they also show sales zone codes, which are also grouped. So a bunch of them would roll off the assembly line and then end up in the same place together.
The big thing I cannot tell right now from these guessed vins and the build sheet is the MDH which is shown on the door tag, which tells me when its built. So I could get a complete inventory of all the freedoms made, and in what colors and such, but tracking down the production times wont be as easy from the vins.
But this means I could also extract some data about other models that were built based on generated VINs...........
Ok I poked around more, I found about 300 sequentially numbered freedoms, 2wd, that according to the single door tag in the sequence I have were built Feb 4th 2000 and it seems these all went to Arizona.
Using the few owner submitted freedom vins I have been able to extrapolate the other freedom VINs out there.
For example, all of the following are 2wd and were sold in Arizona:
1J4FT48S8YL208677
1J4FT48SXYL208678
1J4FT48S1YL208679
1J4FT48S8YL208680
1J4FT48SXYL208681
1J4FT48S1YL208682
1J4FT48S3YL208683
1J4FT48S5YL208684
1J4FT48S7YL208685
1J4FT48S9YL208686
1J4FT48S0YL208687
1J4FT48S2YL208688
1J4FT48S4YL208689
1J4FT48S0YL208690
1J4FT48S2YL208691
1J4FT48S4YL208692
1J4FT48S6YL208693
1J4FT48S8YL208694
1J4FT48SXYL208695
1J4FT48S1YL208696
1J4FT48S3YL208697
1J4FT48S5YL208698
1J4FT48S7YL208699
1J4FT48SXYL208700
1J4FT48S1YL208701
1J4FT48S3YL208702
1J4FT48S5YL208703
1J4FT48S7YL208704
1J4FT48S9YL208705
1J4FT48S0YL208706
1J4FT48S2YL208707
1J4FT48S4YL208708
1J4FT48S6YL208709
1J4FT48S2YL208710
1J4FT48S4YL208711
1J4FT48S6YL208712
1J4FT48S8YL208713
1J4FT48SXYL208714
1J4FT48S1YL208715
1J4FT48S3YL208716
1J4FT48S5YL208717
1J4FT48S7YL208718
1J4FT48S9YL208719
1J4FT48S5YL208720
1J4FT48S7YL208721
1J4FT48S9YL208722
1J4FT48S0YL208723
1J4FT48S2YL208724
1J4FT48S4YL208725
1J4FT48S6YL208726
1J4FT48S8YL208727
1J4FT48SXYL208728
1J4FT48S1YL208729
1J4FT48S8YL208730
1J4FT48SXYL208731
1J4FT48S1YL208732
1J4FT48S3YL208733
1J4FT48S5YL208734
1J4FT48S7YL208735
1J4FT48S9YL208736
1J4FT48S0YL208737
1J4FT48S2YL208738
1J4FT48S4YL208739
1J4FT48S0YL208740
1J4FT48S2YL208741
1J4FT48S4YL208742
1J4FT48S6YL208743
1J4FT48S8YL208744
1J4FT48SXYL208745
1J4FT48S1YL208746
1J4FT48S3YL208747
1J4FT48S5YL208748
1J4FT48S7YL208749
1J4FT48S3YL208750
1J4FT48S5YL208751
1J4FT48S7YL208752
1J4FT48S9YL208753
1J4FT48S0YL208754
1J4FT48S2YL208755
1J4FT48S4YL208756
1J4FT48S6YL208757
1J4FT48S8YL208758
1J4FT48SXYL208759
1J4FT48S6YL208760
1J4FT48S8YL208761
1J4FT48SXYL208762
1J4FT48S1YL208763
1J4FT48S3YL208764
1J4FT48S5YL208765
1J4FT48S7YL208766
1J4FT48S9YL208767
1J4FT48S0YL208768
1J4FT48S2YL208769
1J4FT48S9YL208770
1J4FT48S0YL208771
1J4FT48S2YL208772
1J4FT48S4YL208773
1J4FT48S6YL208774
1J4FT48S8YL208775
1J4FT48SXYL208776
1J4FT48S1YL208777
1J4FT48S3YL208778
1J4FT48S5YL208779
1J4FT48S1YL208780
1J4FT48S3YL208781
1J4FT48S5YL208782
1J4FT48S7YL208783
1J4FT48S9YL208784
1J4FT48S0YL208785
1J4FT48S2YL208786
1J4FT48S4YL208787
1J4FT48S6YL208788
1J4FT48S8YL208789
1J4FT48S4YL208790
1J4FT48S6YL208791
1J4FT48S8YL208792
1J4FT48SXYL208793
1J4FT48S1YL208794
1J4FT48S3YL208795
1J4FT48S5YL208796
1J4FT48S7YL208797
1J4FT48S9YL208798
1J4FT48S0YL208799
1J4FT48S3YL208800
1J4FT48S5YL208801
1J4FT48S7YL208802
1J4FT48S9YL208803
1J4FT48S0YL208804
1J4FT48S2YL208805
1J4FT48S4YL208806
1J4FT48S6YL208807
1J4FT48S8YL208808
1J4FT48SXYL208809
1J4FT48S6YL208810
1J4FT48S8YL208811
1J4FT48SXYL208812
1J4FT48S1YL208813
1J4FT48S3YL208814
1J4FT48S5YL208815
1J4FT48S7YL208816
1J4FT48S9YL208817
1J4FT48S0YL208818
1J4FT48S2YL208819
1J4FT48S9YL208820
1J4FT48S0YL208821
1J4FT48S2YL208822
1J4FT48S4YL208823
1J4FT48S6YL208824
1J4FT48S8YL208825
1J4FT48SXYL208826
1J4FT48S1YL208827
1J4FT48S3YL208828
1J4FT48S5YL208829
1J4FT48S1YL208830
1J4FT48S3YL208831
1J4FT48S5YL208832
1J4FT48S7YL208833
1J4FT48S9YL208834
1J4FT48S0YL208835
1J4FT48S2YL208836
1J4FT48S4YL208837
1J4FT48S6YL208838
1J4FT48S8YL208839
1J4FT48S4YL208840
1J4FT48S6YL208841
1J4FT48S8YL208842
1J4FT48SXYL208843
1J4FT48S1YL208844
1J4FT48S3YL208845
1J4FT48S5YL208846
1J4FT48S7YL208847
1J4FT48S9YL208848
1J4FT48S0YL208849
1J4FT48S7YL208850
