tcharon
- Lake Tahoe, NV
The JackMate® Hi-Lift Jack Accessory is designed as a manual extrication & rescue tool. The JackMate® replaces a standard lift jack's limited capacity top clamp with a multipurpose attachment and is rated to the full capacity of the jack as a clamp, winch, spreader or a base. The JackMate® slides over either end of the jack bar and is attached with a quick-release pin. As a top clamp, the JackMate® dramatically increases the jack's winching, clamping and crushing capabilities. As a replacement for the jack base, the JackMate® ClawFoot™ is engineered to "bite" into boards or logs to help prevent the jack from sinking in mud, sand, ice and snow. Never used. New $40, get mine for $25. Thom 775-410-2389.
