Ecomike
NAXJA# 2091
- MilkyWay Galaxy
xj2win said:Well I finally found it throught NAPA and the Stealership when I asked them for a stator or pick up coil. I'll research the IAC and coolant temp. sensors. I think that something is throwing off either the spark or injector timing. I used a multimeter on the injector wires, and it was getting a good voltage pulse. However, after making sure it had spark we poured some gas into the intake throat and it still didn't even sputter, which is why I believe one of the timings to be off.
Which just confirms what I said below, it was probably already flooded. Try the peddle to the metal trick for a good minute, or more and see if it doesn't finally fire up!!!!! If it does fire up it's one of the items I listed below giving you problems. It doesn't take much to flood it.
