Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Alright, so I replaced a few couplers on my "custom" air intake, and replaced the throttle body gasket. The jet engine sound is gone and my idle is steady, but it's idling sorta high now. About 1000. However, it still struggles to return to idle after getting on the gas. I think I've narrowed it down to bad circuitry in the IAC. Or just a bad IAC (yes, I cleaned it and the throttle body) Does anyone have reference ohm and voltages to the IAC?
Sent from my SM-G930V using Tapatalk
That may be normal, mine idles at about 1200 rpm until I am nearly totally stopped (maybe 5 mph?) when slowing down from say 60 mph on a freeway off ramp to a stop light. I have almost never had a high idle problem caused by the IAC. It has always been vacuum leaks including the MAP sensor vacuum line at the throttle body, leaking fuel pressure regulators dumping fuel into the intake manifold, bad grounds to the TPS and bad IAT temp sensors in the intake manifold.
The IAC is digital, never seen any test voltages published, and the complete Noid light test kits on Ebay have a noid light tester for the Jeep IAC!!!!
