It's SO COLD
bigalpha
Moderator
Tucson, AZ
My heat went out (brrrr) and would like to get a professional opinion.
Does anyone know someone who is a licensed HVAC person around the Clarksville-ish area? Need to get this resolved ASAP.
Affordable Aire Heating & Cooling
525 Cumberland Drive
Clarksville, TN 37040
(931)552-0623
Clarksville Department of Electricity
2021 Wilma Rudolph Boulevard
(931)648-8153
Ellis Heating and Cooling
Hazelwood Rd
Clarksville, TN 37042
931-9803091
Services Offered: Because of our dedication to customer service, the response time by our heating and air conditioning contractors is among the fastest in the area. All of our departments will respond to your needs and get the job done quickly and efficiently. Our employees, from the management and office staff to to the service technicians and field mechanics, have been extensively trained in all the necessary aspects of their departments.
Four Seasons Heating & Air Conditioning Inc
1408 Ashland City Road
(931)648-4411
H & H Heating Air Conditioning & Refrigeration Inc
2547 Highway 41A Bypass
Clarksville, TN 37043
(931)358-2600
Add your HVAC Company here
Local Heating / Cooling Parts Suppliers
A-1 Heating & Cooling
740 Old Hwy 48
931-553-0722
Products: Residential Air Conditioners, Heat Pumps, Gas Furnaces, Air Handlers and Commercial HVAC products.
Action A-C Service, Inc.
1375 New Ashland City Road
931-647-8525
Affordable Aire
(931) 552-0623
Mainstream Heating & Cooling
1539-A Ashland Road
(931) 647-9610
Gotcha back...
Dang. I already left a message with a place my mom used.
It was 54*F in my house this morning, except the bedroom.
i have several space heaters you can use! my heat was out last year, and my landlord took all winter to fix it, then the a/c didn't work when it got hot outside....
i have a buddy here in murfreesboro that does that stuff and needs some work. he'd be willing to travel, and he does a great job. here is his number:
615-947-0966
his name is shawn tanner, and he's a good dude that will hook you up for the cheap. tell him eric gave you his number. if he doesn't answer leave a message. service is spotty at his house, but he'll call ya back!
Cool, thanks. If I can't get any decent resolution around here, I may give him a call.
I also scored some space heaters, so only parts of the house are cold.
Alpha,
Have you taken a look at the furnace? I don't want to sound obvious, nor do i think you are ignorant, but here are some basics:
See if the pilot light went out?
If that isn't the problem, with the older furnaces (again, my experience is only my own ~13 yr old furnace), my first guess would be the ignitor. grab your voltmeter and see if it has continuity and if it doesn't, that might be it.
I wish you the best, and i hope any of my limited knowledge base can help!!!!
I have an electronic pilot.
The pilot will light, but it instantly kills the heat because the limit switch trips.
FrankZ says it's an airflow problem; but I could find no plugs in the system. There is a large amount of rust inside the main panel and I'm sure that inside the heat exchanger is much more rusty.
Heater quits working...
I know it's different but it's kinda the same. Mine went out on the hot water heater and we had no hot water for a few days. (gas hot water heater) When they go bad, the pillot light will not stay lit.
