aeheschutte
- NM
I have a 92 4.0L 4wd manual trans. Heres the issue. I keep grinding my gears when i am shifting, and its not my bad shifting either.(haha) I ensure that i have the clutch pedel pushed all of the way down before i move the stick into my next gear. But if i hold down the clutch for about 5 secs before i shift, the problem is a lot less noticable compared to if i just push in the clutch pedel and shift. I know you shouldnt have to hold in the clutch for 5 seconds before you shift. And the gears grind real bad when shifting into reverse. I am always completely stoped too when i shift into reverse. Am i crazy or can someone tell me that they know what is up mechanically with my XJ?? i can supply more info if someone thinks they know what is up.
Thanks
Thanks
