A fault in the abs wheel sensor circuit could cause one side to brake more than the other. Also could be mechanical, hydraulic issues with brakes that over that the abs cant counter, ie worn pads, grease on rotor, fluid leak, worn, leaky cylinders, pinched off tubes, internally swollen hose, blockages, etc....
Good Luck, Keep Jeeping!
