RichP
- Effort, Pa
Couple of things, early 97's, they have a slider type climate control, check to make sure the defrosters work with the fan on hi, there is this little $1.50 part. a pin in the heater box that needs to be replaced, labor is about $600 as the dash has to come out. It was a common problem on up till 99 or so. Need to get it done on my 97.
Other than that just overall condition, I'd give the frame a once over, we have a 95YJ with a shot frame, rusted over the drivers side rear near the shock mount. We also have a donor frame but did not get around to the swap this summer.
SE is base model, X is next up and has a 4.0, sport is next up then sahara. You may find a 97 or 98 SE with the 4.0, thats the reason they came out with the X, people were saving money buying an SE then ordering the 4.0.
