installing HP dana 44
twitch
Shawnigan Lake
I've been wheeling my XJ for a couple years with a 6.5 lift and 33s. It has gotten some good abuse.....to the point where every panel is smashed to hell.
This rig was my daily driver up until a couple weeks ago.....which means now I can build it and not have to worry about down time.
Im upgrading to 37s from my little old 33s and using hummer beadlocks (7"BS). The d30/8.8 combo is comming out to be replaced with a 44/60 combo. I have started the leaf conversion aswell. I managed to find a d60 rear(FF) and need to know what to find for a front. The trails here are tight and the widest I can really go would be 72"(track width). My d60 measures 63.5 wms to wms and need to match the front. I need some good info on shortening the front. I like to be able to go to the local wrecker and get replacement shafts so custom shafts are not what i want. I do need to keep the 8 lug pattern.
Questions - Which year axle to get for this swap
Which shafts to use? Waggys?
Which brakes will fit the rims?
good info here:
http://77cj.littlekeylime.com/web_rs44.html
to run the hummer rims, you are looking at running 8 on 6.5 correct?
you speced a high pinion, so you are looking at ford units (assuming you want to stay drivers side drop - if not, you are looking at a custom diff)
For outters - im not sure if the 3/4 ton Jeep fronts are 8 on 6.5, but i know the F-250's are.
I believe the hummer rims to be 17's, so no matter what you do for brakes, you shouldnt have an issue..
i would leave the front 44 alone and just use the right ammount of backspacing on the rims.i went with 5 inches of back spacing and it worked out perfect.i also used a 17" rim to make sure i had no issues with clearance.
I hacked my fenders big time and after the front leafs are in it will have the room. I don't see the difficulty here.... a 37 is just not that big. I think a larger tire could fit. The trails around here are tight so I want to keep it as narrow as I can.
leaves on a steering axle with 37's? arent the tires going to rub on the leaves when you are turning?
Im running 12.5s now and don't have a problem with them hitting the LCA. The next set-up will be wider......so no rubbing on the springs
Why would you want to run 37's on a 44? You will break stubs, hubs, ball joints, U-joints and spindles.
Save your money and build a 60. I have broken all of the above with 35's.
I have run 37's and 38.5's on my 8 lug 10bolt front underneath my full size chevy shortbed for a yaer now. I havent broken a single shaft or wheel joint. I am locked w/ a detroit and do rocks.
thanks for the comic releif.:laugh3:
I think your mullet may be helping keep that 10 bolt alive....
