muduck18
- Geigertown, PA
I started this process a couple years ago when I first got the Atlas, and almost immediately found out that it was much larger process than I was ready for at the time. but one thing that I found out in that amount of time is that the amount of Technical directions and installation information for a ATLAS to ax-15 XJ installation is very limited. I'm sure most of that is because of rarity of the manual trans in the XJ.
but what ever the reason, If some one else spends days Googling it. I hope they come up with this thread and some answers to go on.
Lets start with the atlas itself. I found a 2 speed used for a really good deal. and jumped on it, no knowing what I was getting into really, but I desperately wanted lower low range.
So the unique part of this is not the atlas though, it's the Jeep that it's being installed into. Advanced adapters does not have a kit for sale on their website for the installation. And all installation documentation for the Atlas into an XJ is for an AW4 automagic transmission. Which requires an adapter, and spacer and weep hole being plugged.
Not so much for the AX-15. as you can see above it bolts in tight, no spacer, and it properly contacts the seals for the transmission so the weep hole can remain open.
However, The mounting is a different story.
I like to have my rig look and function as close to stock as I can with some added off road prowess. So this is not a buggy, or a full cage, or an engine swap to a v8.. So the next thing I had to do was put the cross member back..
Stock one wouldn't work because of the way it's configured it hits the t-case that now sits closer to the transmission.
These are not the best pictures but I hope you can get the idea.
![IMAG1192.jpg](/proxy.php?image=http%3A%2F%2Fi629.photobucket.com%2Falbums%2Fuu20%2Fmuduck18%2FSuperMassiveBlackHole%2FIMAG1192.jpg&hash=e40ae7dd9fb86cf6352fa44145d9d511)
![IMAG1207.jpg](/proxy.php?image=http%3A%2F%2Fi629.photobucket.com%2Falbums%2Fuu20%2Fmuduck18%2FSuperMassiveBlackHole%2FIMAG1207.jpg&hash=e02ebceef4ddeb41354637c7dff0ad63)
![IMAG1206.jpg](/proxy.php?image=http%3A%2F%2Fi629.photobucket.com%2Falbums%2Fuu20%2Fmuduck18%2FSuperMassiveBlackHole%2FIMAG1206.jpg&hash=773d69500a38829920fdd5530e0943a1)
![IMAG1202.jpg](/proxy.php?image=http%3A%2F%2Fi629.photobucket.com%2Falbums%2Fuu20%2Fmuduck18%2FSuperMassiveBlackHole%2FIMAG1202.jpg&hash=b1ca25601fe78881e864dddb619ca759)
![IMAG1201.jpg](/proxy.php?image=http%3A%2F%2Fi629.photobucket.com%2Falbums%2Fuu20%2Fmuduck18%2FSuperMassiveBlackHole%2FIMAG1201.jpg&hash=ef56fe87a85f47749970e067a7dd05a2)
