CW
- Coeur d'Alene, Idaho
The Ford 24lb injectors will do fine on most strokers without needing any fine-tuning. In some cases, it may be necessary to increase the fuelling by either prolonging the injector "on time" (MAP adjuster) or by increasing the fuel pressure (adjustable regulator).
I already have Ford 24lb injectors and a homebrew MAP adjuster (set to 4.2v) on my 4.0. When I install the stroker, I'll keep the same injectors and bump the MAP voltage back up to 5.0v and maybe slightly higher until the A/F mixture's in the ideal range.
Actually I am running my stroker with the 24lb injectors and my MAP turned down to 4.3v and my Air/Fuel guage is finally reeding stoich. I ran way too rich at 5v and my O2 sensor got so covered with carbon buildup that it wasn't giving the ECU or my guage any input. This is on a RENIXII with the HO fuel rail and HO fpr. I can't figure out why I am having such different results with these injectors.
