If you put any more tube on your rig, it may not be able to move under its own power.
It has the normal tube structure of an exoed xj all external pillars have a bar and a pretty basic halo all tied in through the roof into an internal b and c to keep it from going side ways . The double external B gives the impression of more tube , which that got made because the factory B was supposed to get cut out and fixed tube was to go in place of the doors , but I kept the doors and left the stock b pillar and left the double exo B . What I wanna do is run the inner C thorough the roof into the halo and run a set of internal D thorough the roof run tube from back bumper/crossmember along inner rail and tie into the boat sides and same from front frame horn back ...overkill...yep...but for all of 20-30 pounds of tube the strength of the rig to stay.straight in a roll will be huge .
Going to replace the Warn banner on the windshield with...FURY ROAD ...
