in need of wheel spacers
rexrad25
im looking for a set of wheel spacers for my buddys 2008 jeep wrangler. He needs them pretty bad cuz he keeps tearing up his tires. im looking for reasonable sellers. and at 1 to 2in wide if not 3 in. thanks.
They don't make 1" wheel spacers. Not possible. 1.5" is as thin as you can go in that style. 3" would be ridiculously wide and put a ton of strain on the wheel hub and ball joints. I don't think anyone makes one that thick. 1.5" is what most JK owners go with when they run 35's on their stock rubi wheels. Is that what your buddies set up is? If not, what rim/tire is he running? He will probably want something in the 1.5-2" range. Also, the JK runs a 5 on 5 bolt pattern so finding wheel spacers from XJ guys (5 on 4.5 bolt pattern) may be a challenge. I wheel with a lot of JK guys so I will see what I can find for you.
cool thanks, i did some more research and notice the bolt pattern issue also. and as far as the width range, he said 1 - 3. i told him his best bet was 2. and i dont know what size of tires he is running. im gonna check today. im trying to get some with out him knowing. thanks for the help, i am xj owner and jk's are still new to me
