jmeti000
- san antonio,tx
My 87' 4.0 manual tranny started running hot...at least for it. Last year I swapped over to the open cooling system, heavy duty zj fan clutch, and put in a new water pump, t-stat and sensor. After all that, my temp dropped about 40 degrees...and yes im being serious. It would run around 170-180 without fail. I started thinkin maybe the t-stat was stuck open, and ended up going through about 3 of them before I finally gave up. So here we are, and as of two days ago it ran just as described above. I havent been driving it as much lately, and after sitting for two days I took it out and all of the sudden it gets to about 220-30 while driving on the highway. It tends to inch up the most when pulling hills, and drops a bit on desceleration (sometimes it will linger around 210, but normally a bit higher).
I Brought it home, checked for leaks, cracks, water in the oil, all the normal stuff you would check for, flushed it out and put new fluid in and took it for a spin. It started to climb pretty quick, but when it hit 210 for the first time I could tell my t-stat opened up and sucked water out of the bottle....so I pulled over and filled it up again....and again. No change in temps, still runs hot. The system seems to be holding pressure well, cuz everytime I pull the little lever it spews into the overflow bottle like it should, and Im not loosing coolant anywhere.
I thought perhaps the tranny was gettin to hot, but its a manual and shouldnt really affect the cooling system...right? It got to dark to check that tonight, but its on the menu for tomorrow.
Im really thrown for a loop on this...any ideas?
