Giday
The compass and air temp in my overhead console are powerd buy ignition on, buy tapping into this is it possible to run 6 carlington switches which inturn trigger 6 relays (i havent pulled it apart yet dont know what awg the wire is) but the switches will all have LEDs (fairly low current i assume ) and the relays will all need 200ma(ish) each so i assume if everything is running will the source wire be enough? or will i need to run another wire up from the dash?
Cheers
Cheers
