JJacobs said:
Interesting topic you've got here. I suppose it'd be no big deal to put one on the rollers and start a run at idle, but why? This is something you can't really measure (and have no need to measure.)
Well, from experience I can say there's definitely not 190 ft-lbs available at idle with no throttle.
My reasoning behind the question is this: I'm in a situation where I've got 182:1 crawl ratio available behind a 4.0, and I have frequently overstepped the boundaries of my Dana 60 front axle. To date:
- Broken front 35-spline inner shaft (stock)
- Broken front 30-spline outer shaft (stock)
- Broken front D60 Detroit locker
- Broken front 35-spline drive flange
- Twisted splines on 35-spline Yukon 4340 outer stub
The last three all happened at the same time.
ALL breakage happened at crawling speeds. Meaning, just creeping along, a little *blip* on the throttle, and carnage ensued.
Now, I know what a D60 Detroit should be capable of. I know what 35-spline alloy Yukon shafts should be capable of.
What I'm more wondering here: I've been very impressed with the gearing I'm running. The control and stability I have when crawling over stuff at that low a ratio is awesome. BUT - it has apparently come at the cost of many expensive parts, and I'd rather not be replacing them all the time.
So the bottom line is this - I know what kind of torque a 4340 35-spline stub should be able to handle. At 182:1, this opens up a new world of torque capacity to the axle shafts. I'm fairly certain that I can stall the engine at idle without breaking anything, however I'd like to know if I have any safety factor above this - I.E., if I stall it at idle, I'd better back up and try something else. So far there have been a few situations where a quick throttle blip has gotten me over something, and a few situations where I've broken some expensive components because of it.
As an interesting counterpoint, the rest of the drivetrain consists of Napa 1310 u-joints in all driveshafts, and regular Spicer Life-series U-joints in the axle shafts, and stock front and rear outputs in the D300 case. None of which have suffered at all compared to the front axle.
