- on the beach in Ocean View, VA
OK i charged my battery and checked the voltage on it 12.81 and I installed it back in the jeep... I attached the guage and nothing Im not getting a reading at all i wouldn't see why my guage could stop working outta the blue so im assuming no pressure pumps no good right? well I told my girl to put the key in the on postion so i could listen for priming of the pump.... and with she did i heard a shhhhhhhh sound coming from the pump for a couple of seconds... is this priming? and does that mean the pump is good?
the sound is the pump attempting to prime the system. It does not tell you that it's getting power when you are cranking (listen again while it's cranking)
and it doesn't tell you that the fuel filters aren't plugged up (remove the inlet for the external filter and see if anything comes out when it primes)
Before you dig too deeply into it, don't forget the obvious-- you DO have gas in the tank, yes?
