i have a sway problem
dustin1216
I have a 96 xj jeep with a 6.5 inch rouch country lift i do not have a death wabble but i do have a problem keeping my jeep in the lanes on the road if u have it centered up on the steering wheelif u barly move it to the right it pulls u to the right if u barley move it to the left it pulls u to the left anyone no what i should try i have had an alignment brand new tires drop pitman arm new trac bar tires balanced im stumped
I put the caster were rough country said to put it i will check tire pressure rough country said to have it toed out but i thought i was suppose to toe it in a bit but i have tried it both ways
Doesn't sound like a sway problem, it's more of a steering problem.
Is the steering box in good shape, smooth and snug, lock to lock?
An overtightened center adjustment can mask a loose box.
Dropping it an inch or to would help too.
Caster should be 5 degrees or more. hard to get at that lift, while maintaining an acceptable front pinion angle.
You are at the point where cutting and rotation the knuckles may be in order.
Adjustable ball joints can provide almost two additional degrees of caster.
BTW, do you have a front sway bar?
