You can also put it in park and hold the RPM's at about 3000 for about 3 minutes or so. That, and the Rotella/ MMO got rid of my tick. What year Jeep do you have?
Have you changed out the oil filter adapter o rings and changed the oil filter adapter to SAE threads?. I did that to my 87. Tonight I am going to switch the oil filter to a NAPA 1773 filter just because I can:yap:. The filter is 7" long and will only fit a RENIX with the vertical oil filter mount.
I am in Woodstock. What part of GA are you in?
I'm in Blue Ridge. Actually moved here from 92 a few years ago.
Anyways, oil filter orings just changed. Still the stock adapter though.
I would like more info on the sae adapter and 7 inch oil filter![]()
Does it use the same orings as the metric adapter?
Did second oil change today with rotella and mmo. Looking down through the oil fill the sludge appears to be getting better. Oil wasn't nearly as toast this time either, so maybe there is hope!
Also have not experienced the tick recently, and its even been reaaly cold as of late
I used the 15-40 rotella 5qt to 1qt MMO and Purolator classic filters. It's been 3 months and 8k miles averaging 2k between changes.
