robhurlburt
- lexington,ky
I installed IRO coils up front and made a bastard pack for the rear. I thought everything was too high, but according to the stock XJ specs I only netted 3-3.5in lift over stock. Everything must have been sagging on my XJ, because i measured a 4.25in increase in the front, and 5in in the rear. If i measure axle to the bottom of the flair, it is right at 20.5 all around (netting me 3in per stock specs).
Anyways, along with this has come a problem. I was under the impression that 3in of lift would be fine and would not cause any issues :bs:
As i sits, it the U-joint by the transfer case is knocking. What are some cheap, quick, easy ways to fix this? Cheap being the most important, followed by quick, followed by easy. I will put more time and money into it in the summer, but i would just like to get on the trails for a bit right now.
I have been told:
-t-case drop (is there a DIY on this?)
-Shim the rear axle with angle shims (i think IRO has a kit, not sure if that would work though)
-profit?
Pics:
I have been told:
-profit?
Pics:
Drive line looks steep:
Upon closer inspection:
Yup, you can see the white area where it was popping:
I think it looks good, but i either needs to be lowered, or i need to drop the transfer case.
