Well, I have mocked up where my ram will work and damn, it is a tight fit. I've got a 3/8" between my track bar mocked up IF I bottom out so hard that I blow through all my bump stops (Lincoln style poly prothane coil inserts) that my diff hits my track bar bracket brace (only happened once and it was not BOTW
). I also have 3/8" between my hydraulic fittings and my UCA tower. Tighter than a snare drum.
The issue as I see it, is that I WILL hit it in its current placement and I cannot move it elsewhere without re-fabricating all new front axle brackets.
Here is a pic of the front end straight on (note track bar is disconnected as placed to where I MAY bottom out). It is not TOO bad as far as being exposed but JV will eat it up
A closer shot:
An example of how tight it is (with the track bar disconnected and hanging as if I bottomed out). 3/8" clearance :shocked:
And here is a pic from what I THINK is the view from the underside of the axle looking up:
The reason for this thread is what various designs of 'armor' for the have people done to protect the ram.
I can do something like 2" square from my 'over axle bracket' a foot or so to the pumpkin and tie it back to the axle.
My biggest concern if I do something like that, how much would that hinder me offroad having a bar 5 inches infront of my axle, starting 1-2" above the bottom of the axle tube? I can go 'higher' (3-3.5") to give me the clearance but then if it is too high I think i risk bending it upwards into the ram.
Thoughts?
A closer shot:
Thoughts?
