xtrflexj
- Seymour, Wi
I have a 3 year old Husky Superwinch 10,000LBS that was on my gooseneck for about 8 months used about 25-30 times to winch mud trucks onto the trailer. Always had it bagged when not in use and never left a constant power to it when not in use. The remote cable to run the winch was pinched and sheared off so that is not included, Remotes are very easy to find and should be under 50 bucks. I paid $2,200 for this badass winch and would buy another one in a heart beat if still had my trailer. This winch is very well built and can pull like a tank! Im asking $1,100 OBO or ill take some trades
35+ Tires
Nitrous bottles and lines
dana 60 gears
front xj fenders
smaller winch for my xj
Let me know what you have
125lbs You pay shipping or come pick up
Rated Line Pull (Single Line)
10,000 lb. (4,536 kg)
Motor
4.2 hp Series Wound
Gearing
Worm Drive
Gear Ratio
294:1
Freespooling Clutch
Lever
Wire Rope
3/8" x 90' (9.5mm x 27.4m)
Dimensions
24.69"l. x 9.75"d. x 8.88"h.
(627mm l. x 248mm d. x 226mm h.)
Drum Diameter
3" (76mm)
Drum Length
9" (229mm)
Weight
125 lb. (61 kg)
Reveiws
Designed for both recreational and commercial use, the Husky 10 is one of the most powerful and smoothest winches available for your vehicle. Do not be misled by the nominal 10,000 lbs. rating. The Husky 10 will outpull most 12,000 lbs. and 15,000 lbs. planetary winches.
35+ Tires
dana 60 gears
front xj fenders
4.2 hp Series Wound
Gearing
Worm Drive
Gear Ratio
294:1
Freespooling Clutch
Lever
Wire Rope
Dimensions
Drum Diameter
3" (76mm)
Drum Length
9" (229mm)
Weight
125 lb. (61 kg)
Reveiws
