- La Habra, CA
TunaSoda said:I just replaced my u-joint on the passenger side yesterday, I used a 6" gear puller and the bearing hub came off rather easily
Now if only I didn't strip out one of the holes in my knuckle over-tightening a caliper mounting bolt I'd be driving it today
Is this something I can tap out to a larger size?
This happened on both of my knuckles. Get a Permacoil or Helicoil kit. It'll come with a tap. Drill out the hole in the knuckle according to the directions, tap it, install the coil, then reinstall caliper and bolt.
