xj88kjetil
- Norway
I don't believe swapping injectors in late model XJ's is that good a deal, as they already HAVE a more modern injector type. On the RENIX however, the stock injector are inefficient and don't give a good vaporization of the fuel... I think they are spitting instead of spraying ;-)
(and...
The fuel pump is not a concern if you are worrying about pressure being too high. The pressure regulator will relieve the pressure if/when it exceeds specs. People who modify, stroke etc. their 4.0s usually put in higher flow injectors+a pressure regulator that regulate at a higher pressure. Only then, if a high enough pressure can not be reached/maintained, a more efficient pump should be used.)
(and...
