How much lift do I need?
Rhino1276
maryland
Im curious as to how much lift I need in order to clear 31x10.50x16's with 4.25 BS. I have a 97 2dr 4x4 with 4.0L 5spd. Any help would be great.
Do you have a sawzall? If so, 0".
Search for budget boost lifts... you can obtain 3" by doing a bastard pack in the rear, v8 Grand Cherokee coils up front w/spacer. Use stock JK shocks (all black ones preferred) but you'll probably want to get an adjustable trackbar too.
cut more lift less.
I used 3" coil spacers and 3" lift blocks. I fit 31 - 10.5 - 15 perfect. I do not use it for off road much, just a daily driver. Stock shocks work great to! I am using the factory '99 steel wheels with little to no rubbing at full turn.
