How can I fix this?
KarlVP
Unplug the wire harness and hang it on a tree next to the spot it happened as a reminder to others.:D
Turn key to "OFF" position and remove from ignition. Throw it out the window.
Buy a nice pair of shoes.
Seriously, what happened? Slid into the tree or was just feeling especially fucktarded that day and forgot to stop? :)
Can't see how tweaked the mounts are there, but should be easy to weld back together if you don't care about removing the front clip later. :)
-C
From the little white spots infront of the hood it looks like the hardware was ripped out of the header panel and took pieces of the panel with it.
Now is the time to make a custom front end... one that can take the abuse you give it.
Yeah, how exactly did you manage that?
Baling wire and duct tape are your friend to at least get home from the trail, then I'd look into the mounting points for that clip and replace/modify as required to re-attach it. You may need to fab new mounting points. Man, that's ugly!
Playing with the jaws of life tool or what? But with all the plastic junk up front it is cool that companies are making replacement parts better.
