Where does the hose (that's under the passenger's side carpet) come from/go? 1999, 4.0L, with A/C. I've read the threads related to water in the passenger's footwell, but none seem to describe this particular hose. I know about the short hose that empties into the lower engine compartment (just above the starter), but this isn't it. It goes behind the trim in front of the fuse panel and joins a wire bundle that runs under the lower door trim. I didn't follow it past that. I also can't find it mentioned in the 2000 FSM, but maybe I used incorrect search terms. Could it be a breather hose?
