How much extra bump stop do you need?
I went with a 2" sq 1/8" box tube which I bolted to each side of the frame where the old stops were, then I bolted a set of OEM Upcountry bumpstops to that. so that gives you some 3" more bumpstop.
I forget exactly how much longer the Upcountry ones were, but it stands to reason that if you went up one inch, than the bumpstop might be 1" longer.
If you search around here, you will find different ideas from extensions on the upper leaf plate to a complete rework of the suspension for coilovers.
-Ron
