T THRASHER NAXJA Forum User Location Santa Cruz, CA Jul 8, 2005 #1 went out to hollister hills today to break in the front leafs...still need to get a front shaft but I was still able to flex them out pretty good....
J Jeepkid8037 NAXJA Forum User Location Moraga Jul 10, 2005 #3 So you just wheeled it in 2wd? looks good though. Flex's as good as my short arms...
B baseballneal86 NAXJA Forum User Location Damascus, MD Jul 10, 2005 #4 What leaves are you running up front? Also, what did you do for the rear spring hanger? Use the LCA mount? Thanks -Neal
T THRASHER NAXJA Forum User Location Santa Cruz, CA Jul 11, 2005 #5 I am running waggys in the front, I did use the lower control arm mount as a spring hanger, beefed it up a little though....
J Jeepkid8037 NAXJA Forum User Location Moraga Jul 11, 2005 #6 Did you drill a new hole or use the stock LCA mounting holes? Arent they drilled at an angle?
