- Green Valley, CA
Don't have pics right now, and the stuff is buried in the Jeep.
I've got a hitch from a 97, recently on a 98 XJ. It includes the hitch, nutstrips, and bolts. 50 OBO. I also have the plug-and-play wiring I'll toss in for another 25 or so.
The tire carrier is the factory one, off a '84 XJ. I stumbled across it in the junkyard, pulled it off, and made it fit my 98. Included are the modified late-model bumper, tire carrier, inner upper and outer bracket, latch bracket, latch backing bracket, inner and outer lower bracket, and all the bolts that came out of this thing (assuming none rattle loose on the trip home) It is drilled for 5 on 5.5, as well as the stock pattern. I've got it set at 5 on 5.5 now, and you'd have to cut some tack welds to change it back. Asking $100 OBO.
Edit: found a pic of the rear of the Jeep. You can see the tire carrier and the trailer hitch here.
Edit two: reply here to hold your spot, but PM if interested, as I don't always check the fo sale sexion.
