Hey guys, I understand that this issue is constantly beaten to death but I'm at my wits end and need some help.
I have a 1997 XJ with 212k on chassis and 98k on the replacement 4.0 (done by P.O) that's having some issues which I've researched the hell out of and repaired most of them, to no prevail.
The Jeep starts easily, runs fantastic for a minute or so, then begins with typical bouncing idle, misfiring, sputtering and stalling. I can keep it alive in park/neutral just fine but if I give it much throttle input under load, starts pinging and cuts power. I get no CEL.
Here's what I've done and replaced to try to remedy the issue:
- New ignition coil, cleaned grounds to block.
- Checked plugs and wires for spark
- P.O had replaced the cap and rotor which I went through anyways and cleaned the contacts, dizzy also appears to be indexed properly, haven't checked cam sensor. Don't think it would run as well as it does (momentarily) if it was 180* off.
- Replaced the infamous cracked exhaust manifold and gasket because I thought maybe it was sucking in unmetered air and throwing the AFR off.
- O2 sensors are good, relatively new and again, no CEL's.
- Replaced the crankshaft position sensor with MOPAR, it had low resistance but replaced anyways in the event of a thermal short or similar. The one I pulled out reads anywhere from 550-740+/- from pins B to C and the MOPAR reads the same. On this topic, it cranks and feels like it hits a rough spot briefly then pulls through and starts right up.
- Cleaned and checked voltages of MAP, TPS, IAC & all related.
- Checked vacuum lines
- Checked voltage and resistance on almost every wire possible however don't have much knowledge of the PCM and didn't go too far into it. Don't know how to go about checking the ASD.
- Cleaned every connector with wire cleaner.
- Checked and cleaned grounds
- Checked all fuses and relays
- Checked fuel pressure and fuel leak down (it's at a strong 48psi and doesn't leak down for hours)
- Compression is good, tested around or above 140.
- Probably quite a few more things that aren't coming to mind at the moment.
Have NOT looked into the clock spring/cruise cont shorting issue. The cluster doesn't typically work upon startup but works if I bang on the bottom and top a couple times, airbag light will illuminate when gauges aren't working but goes away after banging on it and gauges begin working.
If anyone has any suggestions that would be great. I'm mechanically inclined but I feel like I just need a push in the right direction or someone to spark the lightbulb on whatever I'm overlooking. I've done all I can at this point.
