brothrDave
- dublin,ca
hello everyone, while @ Hollister toy run I/we (ie: My Daughter) Broke my right rear axle 35 w/ARB. So I removed the cover @ home to find that the brass tube for the locker broke also the bearing must have spun pic#1 (A) but the problem is I can not figure out how to get to the C-clips to remove them and the broke peice of the axle. also pic#1(B) are the teeth marks normal or do I have something else to worry about. And do I have to remove the end of the axle in pic#2 by removing the "Hex Bolts" then should the other outer broken piece slide out or do need to persuade it a little thank you in advance for any of your help I know I need to upgrade to a 44 but $$$ alittle tight and I do have spare axles just need a little help Thxs BroDave
