AwesomeXJ
- Vancouver WA.
So the tc shifted perfect when we put it in. But now it will only do 2h and half way to 4h. It makes no sense.
This is where "I" would start..Also, make sure you also have the shift linkage installed correctly. There's the linkage tab on the side of the case (held on with 9/16) that can be installed 180 off. Should point up if I remember correctly.
If it's binding on sides, cutting it won't make a difference. Try "clocking" the tail housing just a bit to bring the rail off the side of the tail housing. I had a similar issue one time, and found that there was just enough play in the tail housing bolt holes that you had to make sure the rail was centered in the tail housing slot. My rail was getting caught up on the sides preventing it from releasing back into two wheel drive.The shift rail is contacting the side of the cavity. Can i just make it bigger or do i really need to cut The rail?
its in and working. Just got to bolt the cross member up and he should be on the road.
Bronze.
home safe aaron?
