Barger
- DelaWhere?
I pulled the T-case apart to find out why I had endplay in the front output shaft. This started shortly after a SYE install. Could I have missed something? I'm sure the front yoke nut is tight.
I can see where the shaft is contacting the back of the case.
About the only thing I can figure is worn would be the bearings as there is not much else to the front shaft
How hard are they to replace as I don't have the "Special tools" reffered to in the FSM?
Would just replacing the rear bearing solve the problem or does the front bearing play a big part in the endplay as well?
Brian
Brian
