Hamzahng
- Dubai, UAE
Hi all,
this is my first post on this forum. so I thought to introduce my self first. I am Hamzah, and I am from Dubai. I have an american import '98 XJ.
I have recently bought a 55W LED Headlight. and it has a DRL Pin which I connected to the Parking lights. they are running nice except that the left Low Beam is always flickering, and the DRL is not turning on at all
I have been reading online for a solution where I found that there is an upgrade kit which consists of a couple of relays and it connects to the light to give it the full power. I have decided to make one on my own since I am and Automation and Electrical Engineer. I have all the circuits drawings with me but I don't know how to upload them here
now for the questions:
I was thinking of the Parking lights, whenever you are using the blinkers they will start blinking therefore it will be redundant to use them. so I want to connect them in an inverse connection with the Low Beam lights therefore whenever the Low Beam is off, the DRL will be on. but the problem with such a design is that whenever I turn off the car, the DRL will always stay on. to fix that issue I decided to connect a relay that is coming from the Ignition Switch. << How can I do that ... can anyone help me in connecting a relay to the switch so whenever the car is on the relay will be on, thus the DRL can go on.
or if anyone as a better idea on how to connect the wire for the DRL to follow the above logic.
Thank you guys.
Thank you guys.
