get a vacuum gauge and run a vac test....as you know this will tell you much about your valvetrain....depending on what kind of dance the needle on the gauge is doing.
Based on what i heard in your video you can probably rule out a lifter.....a stuck/collasped lifter will make a higher pitched tick almost like an exhaust leak(ask me how I know).You have almost a rod knock sound there but im leaning toward piston/wrist pin noise....
I would also do a compression test......
To me this really sounds like too much piston clearance,I.E piston slap.....hell could even be a bad wrist pin....letting the piston(s) rock in the bore and slap against the cylinder...:lecture:
Should do another video with the motor being reved and held for further diagnosis.....
I just listened to that video again....could it be spark knock(preignition)???
