Head Gasket Repair Cost?
d10shun
Az
What did you guys pay to have a head gasket replaced by a mechanic? I know I could figure it out but I just don't have the time. Thanks!
You should post this in your region's forum. What a job would cost in NYC, LA, Las Vegas, Salt Lake City won't mean a lot to you in AZ.
Also, what is involved, and the cost, can't be determined until it is torn down for inspection.
Will do.
Figure 4 hours or more. $300 would be cheap.
I just did a HG on an overheated 95. I took the head to the machinist to get a valve job(I provided the ~$20 seals), and shave the head flat($250). The head gasket cost $30(discount from someone on the stroker site). The t-stat $5, the manifold combo-gasket $20, the valve-cover gasket $25, two bottles of coolant-$20. So ~$350 to do the job right and I did all the labor, save for the machining.
