Thanks guys. I pm'ed xjnation. So I have seen a lot of discussion, but no hard answers. Threre is debate about what yokes will or won't work. I will probably do the same thing as everyone else and go to the parts store. I wanted to just get one out of the junk yard. Yes I know how hard they are to get off. How much do they run new? Also, brake lines. I will just have to go to NAPA since everyone says that is where they got there's. My lines thoughy were a central line that came to the center of the axle and then split. I don't need that obviously. I wanted to just hook up the flex lines to my existing lines with an adapter. Could I have new flex lines made with a standard end? It would be more expensive, but would take care of extended lines later on.
Also Grin, I just Googled "wheel Adapters" A couple of companies came up. The problem is from what I saw was that they had to make 2 and put them together for 2" total on both sides. I was going to call them today. I was going to use 1" spacers later anyway so maybe I could use that part and not waste money. They were $130 for the pair. What would be wrong with re drilling? I could just go to the yard and pull extras for later.
