Hard to shift 231, this could be you!!
willysnut
Newnan, Ga.
Having just rebuilt my XJs 231, I was stumped that it was hard to shift and popped out of low range. :confused: So back to the FSM to see what was wrong.:banghead: After reviewing the pics I found out that I had put the "mode sleeve" in backwards which allows you drive all over town and put the TC in 4high,2wd, but not fully into 4lo. Now that I split the cases to correct that problem it shifts like it is supposed.
:anon: I'm so ashamed! Let that be a lesson to all who rebuild their 231. :party:
my 90 has a REALLY hard to shift lever.
It all works fine, fluid was good and was changed...
It's still really hard to pull on the lever.
Original untouched T-case afaik.
Command trac.
Teron
is the mode sleeve the blue ring on the output shaft? if not what is it because i have this prob. and it needs to be fixed.
