Happy Holiday’s Sale! Gears, Bearing Kits, Lockers and Axles
Status
Not open for further replies.
Just wanting to know if you have any chromoly axles in stock for a 29 spline C8.25 rear axle in my '98 XJ, and what brand are they? I bought these from another shop, but they might not have them in stock. Need them pretty soon, complete with bearings and seals if they don't come with the axle. Also need the spring rebuild kit for a Powertrax no-slip in the same axle. Quote shipped to 22042 please.
Detroit locker 4. whatever and up for a 35 spline Dana 60
5.38 ring and pinion for a gm 14bolt full floater
install kits for both
shipped to 95926
can you make that an itemized quote please, Thank you
make that a 5.13 R&P
need 94 chevy 14 bolt ff 4.88 gears, master install kit, lube locker
reverse cut dana 44 4.88 gears, master install kit, lube locker and tube seals
shipped to 78374
Can i get a quote for a empty carrier, 30 spline, spicer or Yukon for a dana 44. 3.92 up.
2 each spicer 5-760x U-joints
3 each spicer 5-153x 1310 U-joints
Shipped to 95834
Can I get a quote for:
D30 High Pinion 4.56 gears
Install kit
Carrier center pin
Carrier center pin retaining roll pin
Shipped to 85345
thanks
Can I get a quote for a 4.10 gear set for a HP Dana 30 and Chysler 8.25, along with installation kits.
I hope everything is ok with him. I'm still waiting on a quote from dec 18th
Sent from my T-Mobile G2 using Tapatalk
Shot in the dark if this thread is still going but...
Can i get a quote on some 4.56 for a d30 and 8.25 to 29715.
Thanks
Howdy,
I need a set of 4.88s for my 96 cherokee with a dana 30 front and dana 44 rear. I will also need the master install kits.
Shipped to 94534
Thanks,
Status
