Just fixed the grinding noise in my front end last night. It was the wheel bearings. To check, jack it up, grab the wheel at 12 and 6 and see if there is any play. If so the hub assembly needs to be replaced. Do a search on wheel bearings or hub replacement or even replacing front axle shafts (pretty much the same job) and you will find many threads with info on how to check/replace these.
