Great vehicle.
Recently did a Tranny filter and tranny cable change.
Took it on a long drive. Made it fine, no problems, although running a little hot (it was hot out too). At the end of the drive I got into town, slowed down, and on slow left turns I heard a bad grinding sound, coming from under me and just to the right I think. I also heard it going straight and right but mostly left.
Changed a wheel bearing, u-joint, checked the others, removed the front driveshaft. Figured I was good. Drove home (6 hours). Made it fine.
Got into town, turned left. Grinding.
Now it drives fine but the grinding is more subtle, but happens after just 10 minutes or so of driving. Don't notice it at highway speed, but maybe something feels a little friction-y.
Front brakes are new and close to the rotor but braking doesn't make it worse/better.
Really can't figure this out. Would love your thoughts (so long as those thoughts aren't useless like "you should take it to a mechanic."
