Gotta find out...
Wondo
Elysburg, PA
Hey everyone...
I gotta find out if a set of Rancho's control arms that came off a 3 inch lift will work with my rig..i got 3 inches on it now with the stock ones..but im' gunna be going up to about 4.5...will the ones from rancho work????
thanks
I believe 3" and 4.5" use the same lowers, so, yes, if it's just the lowers. If the uppers are adjustable you're all set...If the uppers are fixed for 3" you'd still be somewhat w/i range, I think, just not perfect for caster angle.
Rancho arms suck,as already stated(in other thread) they bind on the shock mounts!They also use small diameter poly bushings which bind and blow out when even remotely flexing!
