Got some boxes I need
RyanM
va
This is my Clutch Master Cyl/Slave Cyl Hydraulic system (94-96's). 140K is enuff for my Stock unit. My clutch pedal is getting badd. Got it from www.chryslerpartsdirect.com, you can see the chrysler tag. 100 cheaper than dealer. Before I came here, I never new of the sealed unit, so all 94-96 guys with ax15, be on the look out. And be careful, they come ready to go with fluid. I managed to spill some on my self:cry:I'll post my results in the OEM forum tonight
My precision set is starting to make a faint noise out back, plus I have beat the hell out of it. I have plans for new superior shafts, truss, ladder bar and to re do the vent setup, so for peice of mind while i got it pulled and Im gonna rehaul her with a fresh spicer 4.89 set. got install kit, extra shims, and a new cover with HP fill hole.
SWEET MICROWAVE!
I like the beer on the passenger side tire.
You set that there after you got out? :)
I was getting ready to play softball ;)
Other side. You can see my stabilizer. welded a piece on my TBframe mount, and made a piece for draglink. Helps on the back roads i guess, i like the feel of it. researching hydroassist now, still gathering
Its ok, Just ordered stiffeners, then ill weld my sliders on maybe add some gussets. and get new bumpers.
Who has TNT's Ubolt elims? do you like them.
I have the Ubolt eliminators. I like them, You can run a flatter leaf, get up to 1.5" of lift, it helps out with axle wrap and no U bolts. Down side is you still get some axle wrap when you get on it heavy and I think the large plate on top might hinder some flex. But for the most part they do what they are supposed to do.
thanks for reply, do you have the 8.8 tuss as well?? I was thinking about using them to strecth my WB a tad, but i might just cut a hole in these new perches, and the plate.
Speed_racer said:
Nope, he glued the new "crush proof" can to his tire....
Heeerrreee's your sign!
I was referring to the drinking and driving, but I suppose my level of humor must be above yours.
