Good Leakdown with Bad Compression
Okay. So, she's putting again. Replaced the bent pushrod and pulled all rockers. All valves appear to be sitting correct with a strait edge laid across the tops. Re-torqued rockers down. Pulled fuel rail. Injectors were nasty. Replaced with a newer set. Cranked it up with valve cover removed and waited for oil to reach the rockers. Runs great.
Problem solved for now.
AWESOME!! Thanks for the followup and nice work!
The one thing I'll say is that I put gasoline on the new o-rings on the injectors. Made it easier to install. However, they sprayed a good bit of fuel out and didn't seat properly. I'm guessing the gasoline didn't allow for a good seal.
After a few starts it got better. Assuming after the fuel cleaned off the vasoline. I'll start it again tomorrow to be sure. Also, does smell rich anymore. Really running better than before. Might swap the injectors for the 4 hole sprayers in the future. But, for now, she's good.
And yea, thanks. I hate reading threads and never seeing a conclusion or follow up.
What did the spark plugs look like? Picture? Intake valve sticking? Collapsed lifter? I would pull the valve cover and whack the valve stems with a hammer. Inspect for bent push rods, etc.
If the intake valve is not opening on #2 that would cause this data right?
Edit, I see after reading the rest of the posts, you all already figured it out, no Mojo on opening the #2 intake valve. I have a lot of slop in my 291,000 mile push rods, from wear, guess its time to do that head job and replace everything before I get a bent rod.
Mike, if your hydraulic lifters can maintain "zero lash," life is good.
The one thing I'll say is that I put gasoline on the new o-rings on the injectors. . . . . .
After a few starts it got better. Assuming after the fuel cleaned off the vasoline. . . . . .
Good thing I read your entire reply. :)
They are a wee bit loose when the cam lobes go to their lowest height due to Wear on the rod ends and rockers. I read somewhere they should not have zero lash at that point that you should be able to rotate the rods then. Mine are loose enough to be obvious, and loose enough to tick just a wee bit.
Unless I do not understand zero lash? That is zero movement of the rocker, zero gap, at BDC of the piston? I may have as much 1/16" on some. Definitely 1/32" I think. I did not measure it.
I have an entire new set of parts already, and spare head for the engine shop to prep, its a roundtoit thingy.
Pushrods and rockers won't wear enough without failure to cause that slop but a cam and lifters will. Zinc is missing from modern oils that our flat tappet cams desperately need to live.
You have not seen my rod ends and rockers and pivots, LOL, or the valve guides for that matter. I guess we will know about the Cam once I have replaced everything but the cam.
I have enough zinc and additives in mine to gag a maggot LOL. I wrote the book on the ZDDP issue here over 10 years ago. Probably why mine is still running.
