Gears
arctycfox
Arvada
ok, thought i knew how to figure my stock ratio without pulling the cover, but the answer doesn't make sense, so i must be doing it wrong. How do you figure the ratio out without spending the money on fluid. I jacked up the rear end, put it in "N",spun the driveshaft and counted the number of turns the tire made, to the number the shaft made and ??? The driveshaft spun about 1.5 time to the tires 2. Help please.
Adam
Re: gears
Its a 5 spd 4.0 w/ np231 right? 3.07 gears, 99.9% chance those are the ones.
One of the diffs should have a tag on them, it'll be attached by the bolts that hold on the diff cover.
Re: gears
I second that. 99.9% 3:07's.
