buffalo
- Los Angeles, CA
What is the best gear ratio to have with 33" tires for street driving and off-road, I have 4.10's now and not the best
Thank you for your information, it has an automatic and the rear is an 8.25
IIRC, the 4.56 is the lowest (highest numerically) ratio available for the c8.25. So if the OP is not happy with the 4.10, its either the 4.56 or the 4.56.
Nope. I run 4.88's in my 8.25 with no issue. I wouldn't go that deep if I was at sea level but my tired engine needed some help maintaining 65 through all the mountain passes I have around here. If you don't mind running 3k rpm at 80 mph, it's a good gear.
