Yes, they are the same. When doing gear ratios I've "heard all over the internet"(a dangerous thing to say, I know) that a 2% difference in the numbers is the maximum acceptable diff before you run into problems.
So pardon my ignorance and misunderstanding, but is the answer yes I can safely use 4.10's up front, and 4.11's in the rear. Also i forgot to mention, I will be adding an EZ locker in the rear and sone form of locker or limited slip in the front, will this make a difference? I will be using the jeep primarily offroad.
