JEEPTUBE
- citrus heights
How much gas will my 1997 XJ gas tank hold?
It is a 4.0 ho with auto
:confused1
:confused1
Damn, 20?
Everytime i fill the tank it goes to 16 and cuts out. I wonder if my gas gage is reading wierd? It has never done anything bizar before.
I think the pre 96 had 16 gallons cause mine does the same exact thing. Sorry for ressurecting an old thread, but I have been researching this![]()
my 96 had a 20 gallon when I got it, and now has a 97+ 20 gallon in it. I'd suspect the sender is screwed up if it reads as empty with 16 gallons gone - OR you've bounced it off too many rocks and it is now a 16 gallon tank, the old metal tanks didn't like that quite as much as the plastic ones and with that stupid plastic scuff plate over the tank it's easy to not notice that they're caved in.
Older ones had 15gal std and 20 gal optional. I only get 18 when I fill up, cuz the PO put a dent in the tank.
Only on right had turns?!?! LOLNever heard of anything less than 20. Could be for the 4 banger pre 1987. I always get a fill up of about 15 +-. I'm happy for the reserve.
My 90 has the fuel pump from Napa in it and it did not quite fit. When it gets low, the engine cuts out on right hand turns. Been that way for... oh 15 years?!
